two profiles on same computer, when one has Firefox open and connected to the Internet, Firefox in the other profile does not connect
automatic updater has updated Firefox on profile "Gordon" but on profile "Leslie" it still shows the earlier release. These two may be in conflict. It seems like there might be a Windows problem as the "Leslie" profile is using a different release...
That is as it should be, you can only have one default browser and one default profile, If Firefox is already open you will use the profile that is in use, unless you open with -no-remote on the start for the second Firefox. Never use -no-remote on the default profile and never use the default profile with -no-remote and you will avoid problems.
